Out-of-scale Pergola? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 04:20 PM   #1
Rewards Points: 83
Hi there,
I am not sure if this is the right part of the forum to ask this but here it goes:
We're looking to build a backyard patio using pavers. My wife would ideally like to add a Pergola to it. From what little I know, I've heard that a pergola should be a certain height in order for the scale and perspective to be correction. The patio would be right behind out kitchen (no other options) and our kitchen has a big window looking out the back yard. I'm told that if we build a pergola of a standard height, the top will block the window. If we build it higher, the sense of scale will be wrong.
Can anyone share in more detail what is meant by the "sense of scale" being wrong? If it refers to the scale when sitting within the pergola, are there any tricks to hide this issue?
Would we have to raise the height of the patio to compensate? Since we're using pavers, how would that most easily and cheaply be accomplished? Perhaps by using cinder blocks under the pavers and then infilling with dirt or gravel and surrounding with wall stones? Or is that not a good idea? I imagine doing this against the house would not be wise ... maybe pushed back a few feet to avoid trapping water against the house?
Thanks for your time and patience with all the above questions.
darthsmozers is offline   Reply With Quote
Old 01-27-2013, 04:38 PM   #2
Rewards Points: 14,306
And the picture of the house is where so we can see what your talking about?
woodworkbykirk (01-27-2013)
Old 01-27-2013, 09:43 PM   #3
Rewards Points: 83
Good point. Sorry... tomorrow I will try to do just that
Old 01-28-2013, 09:48 AM   #4
Rewards Points: 83
Please see attached.
Old 01-28-2013, 10:47 AM   #5
I see what you mean now.
Several issues.
Your going to need to build a retaning wall on two sides.
Going to have to change that gutter down spout so it runs under ground.
And it will look strange having to sit up that high to clear that window.
Old 01-28-2013, 11:00 AM   #6
"You can do anything"-Mom
brockmiera's Avatar
That seems like a lot of work just to have pavers. Have you given any thought to just building a wooden deck? That way you could keep the existing grade of your lawn and just compensate with longer support legs on the right side of that picture?
Are those sliding doors on the left side wall on that picture?
brockmiera is offline   Reply With Quote
Old 01-28-2013, 11:26 AM   #7
Rewards Points: 83
Yes those are sliding doors on the left.
Pavers seem much more inexpensive than to build a wooden deck, thats why we thought to go with pavers. The pergola isn't essential, so if we just went with the patio itself it seems pretty simple. But if we want a pergola, I imagine we'd have to raise the patio to make the scale correct. Would cinder blocks under the pavers do that OK?
Old 01-28-2013, 11:26 AM   #8
Rewards Points: 83
Several issues.
Which sides will get the retaining walls?
Old 01-28-2013, 11:30 AM   #9
Newbie Bill
Rewards Points: 522
The side closest to the camera and the side on the right.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 01-28-2013, 11:31 AM   #10
In the picture it would be the right and area away from the house.
If there is no retaining wall anything under pavers is going to wash out.
Old 01-28-2013, 11:45 AM   #11
brockmiera's Avatar
I may be making this too simple but it seems to me that a nice option would be a deck that is the same left as those sliding doors on the left of the house. I'd put my pergola on that side then have a wrap around option maybe with steps down to another deck. Of course if money is tight that isn't the best way.
At any rate, maybe the creative juices might get flowing.
The Following User Says Thank You to brockmiera For This Useful Post:
drtbk4ever (01-28-2013)
Old 01-28-2013, 12:36 PM   #12
I agree, but would make it free standing.
Old 01-28-2013, 01:21 PM   #13
Rewards Points: 83
Sorry, I am a little confused. Do you mean a raised patio using cinder blocks and pavers would wash out, or do you mean simply using pavers would wash out?
Old 01-28-2013, 01:36 PM   #14
Newbie Bill
Rewards Points: 522
Installing pavers (including a raised patio) on the slope that exists there now won't stay put for very long. Gravity and the effects of weather will cause them to move downhill.
The pavers need to be installed on relatively level ground (a very small slope to move water away from home is suggested) with the appropriate preparation materials laid and compacted before the sand base and then pavers.
You don't have very much room to build a raised paver patio as your siding looks to be only 5 or 6 inches above grade at the corner.
Bill
Last edited by drtbk4ever; 01-28-2013 at 01:43 PM. Reason: Sorry, had to add some information and correct spelling.
Old 01-28-2013, 01:43 PM   #15
Rewards Points: 83
Oh OK I understand now.
Do you think pavers alone on the ground would work with that slope?
Refrigerant Charging Scale benjamincall HVAC 14 07-13-2014 06:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Deck and Pergola getzjd Project Showcase 17 07-02-2011 09:36 AM
Pergola on Elevated Deck stubits Building & Construction 0 06-19-2010 08:48 AM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 08:30 PM
