Old 12-18-2007, 08:51 PM   #1
OSB Walls in Garage
I just installed OSB in my garage 26x36x14 and I want to fill in all the seams and nail holes prior to painting. Does anyone have any suggestions?
Chris B is offline   Reply With Quote
Old 12-18-2007, 09:33 PM   #2
General Contractor
joasis's Avatar
OSB Walls in Garage
Latex caulk.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 12-18-2007, 09:42 PM   #3
OSB Walls in Garage
Someone told me there is a compound that is thicker then joint compound, that is used on wood. Any idea what they might be talking about?
Old 12-19-2007, 08:38 AM   #4
Master General ReEngineer
Bondo's Avatar
OSB Walls in Garage
Ayuh,........
Latex caulk.
Old 12-19-2007, 12:21 PM   #5
OSB Walls in Garage
Maybe they're talking about something like bondo general filler?
NateHanson is offline   Reply With Quote
Old 12-19-2007, 02:32 PM   #6
Woodworker and Contractor
Kingfisher's Avatar
OSB Walls in Garage
If you went with OSB over drywall why are you worried about the cracks now? just calk them.
Kingfisher is offline   Reply With Quote
Old 12-19-2007, 07:02 PM   #7
OSB Walls in Garage
The OSB was used instead of drywall. How would mastic work?
Old 12-19-2007, 07:07 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
OSB Walls in Garage
- Build Well -
Old 12-20-2007, 11:12 AM   #9
OSB Walls in Garage
Is this garage attached to your house? If so, what fire retardant material did you use?
Mike13 is offline   Reply With Quote
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
Raising existing walls of a garage ok2rvtravel Remodeling 3 10-09-2007 12:45 PM
Crazy Garage Extension, Building over blacktop?!?! commissure General Discussion 4 09-13-2007 12:09 PM
