-   -   OSB Walls in Garage (http://www.diychatroom.com/f19/osb-walls-garage-14577/)
Chris B 12-18-2007 08:51 PM
OSB Walls in Garage
I just installed OSB in my garage 26x36x14 and I want to fill in all the seams and nail holes prior to painting. Does anyone have any suggestions?
joasis 12-18-2007 09:33 PM
Latex caulk.
Chris B 12-18-2007 09:42 PM
Someone told me there is a compound that is thicker then joint compound, that is used on wood. Any idea what they might be talking about?
Bondo 12-19-2007 08:38 AM
Ayuh,........
Latex caulk.
NateHanson 12-19-2007 12:21 PM
Maybe they're talking about something like bondo general filler?
Kingfisher 12-19-2007 02:32 PM
If you went with OSB over drywall why are you worried about the cracks now? just calk them.
Chris B 12-19-2007 07:02 PM
The OSB was used instead of drywall. How would mastic work?
AtlanticWBConst. 12-19-2007 07:07 PM
:huh: :whistling2:
Mike13 12-20-2007 11:12 AM
Is this garage attached to your house? If so, what fire retardant material did you use?
