Osb Vs. Plywood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2007, 06:05 PM   #1
weekend warrior
Rewards Points: 150
osb vs. plywood
I've been reading about the two products. I'm hearing conflicting information. Some websites say they can be used pretty interchangeably. Some say to never use the OSB in certain locations due to the edge expansion. What is the concensus here as far as the following applications:
-exterior wall sheathing
-subflooring
-roof sheathing
-any others?
here's some seemingly good info from http://www.umass.edu/bmatwt/publicat...s_plywood.html
Subfloors and underlayments serve as structural platforms and as a base for flooring products. Osb and plywood are equals structurally, but flooring manufacturers make different recommendations regarding their use as a substrate.
Joe Tarver, Executive Director of the National Tile Contractors Association, Jackson, MS says, “ Osb is not an acceptable substrate to receive ceramic tile, period!”
Wall sheathing: No news is good news. All manufacturers of siding products I contacted agree that osb and plywood are equals. Kevin Chung, Engineer with Western Wood Products Association in Seattle assures us, “There have been no problems reported from the field. Nail-holding and racking resistance are the same.” Chung has noticed some concern about the use of osb among builders, but is quick to add, “There is no reason for any concern. Both products serve equally well as a nailbase.”
johnny331 is offline   Reply With Quote
Old 05-29-2007, 06:48 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
This is our feeling on the matter as well as the General contractors that I am acquainted with in my region:
Wall sheathing: OSB ok
Roof Sheathing: We never use OSB, just CDX
Floor sheathing: We never use OSB, we prefer advantek sub floor
- Build Well -
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 06:29 AM
Exterior plywood, not secured well enough mt232 Building & Construction 4 07-03-2007 09:34 AM
Exterior plywood mt232 Building & Construction 1 06-25-2007 08:59 AM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Remove Plywood Subfloor? cpbraun Flooring 3 11-20-2006 08:24 AM
