Osb Vinyl Siding Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2011, 05:59 AM   #1
osb vinyl siding question
this shows the value of a community like this. i have now abandoned the idea of ripping 2x4s into siding or trying to use cheap composite or even t1-11. Im now thinking ill use osb covered with vinyl siding.
if i put up osb, how many rains can it withstand before the siding is up? does the siding have to go on immediately or can it wait a while/ I'm not experienced in any of this.I'm learning by doing and that's why all your comments and advice are helpful because I know most of you speak from experience. Thanks-
jjjeno is offline   Reply With Quote
Old 04-15-2011, 06:55 AM   #2
Rewards Points: 2,240
Wrap the OSB with "Tyvek" or 15# - 30# felt - nail it on so it doesn't
blow off.
OSB doesn't like water.
rossfingal
rossfingal is offline   Reply With Quote
Old 04-16-2011, 08:01 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
most lumber yards carry this now,no wrb required
http://www.zipsystem.com/
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
loneframer (04-16-2011)
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 10:28 AM
Storing Vinyl siding in attic? Deform? rebar Building & Construction 2 08-18-2010 10:15 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 06:27 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
