Old 05-17-2011, 02:43 PM   #1
OSB Sheathing Question
I am using OSB sheets for the inside walls and ceiling in my shop. When the pieces of the wall and the pieces of the ceiling meet, should the ceiling sit on top of the wall or should the ceiling run into the the top of the wall?
IdahoNeedsHelp is offline   Reply With Quote
Old 05-17-2011, 03:31 PM   #2
Framing Contractor
The ceiling should be run first. The reason is that if the ceiling ever droops, the edge will still be supported by the walls.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
IdahoNeedsHelp (05-17-2011)
Tags
ceiling, framing, osb, walls
Mold on roof sheathing!!! DIYMILF Roofing 10 08-14-2011 10:11 PM
Thinstone on sheathing 3/4" off of the foundation Kasper Building & Construction 3 08-27-2010 09:57 AM
House without exterior sheathing? magnusrw Building & Construction 2 06-06-2010 03:13 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
