OSB Or Plywood - Which Would Be Better? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 03:36 PM   #1
OSB or plywood - which would be better?
I'm putting in a sub-floor on a screened in porch. Would it be better to use OSB or plywood? Treated or untreated? The construction used to be a deck, it is now roofed and screened-in. The decking sits about 4 feet off the ground.
kratsnire is offline   Reply With Quote
Old 02-05-2011, 03:38 PM   #2
Experienced
Jackofall1's Avatar
You say its screen in, will the floor get wet when it rains?
Treated ply at a minimum.
Mark
Old 02-05-2011, 03:45 PM   #3
Thanks !
Old 02-05-2011, 03:46 PM   #4
Framing Contractor
Originally Posted by kratsnire View Post
Thanks !
What will your finished floor be?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-05-2011, 04:08 PM   #5
Indoor/outdoor carpet
Old 02-05-2011, 04:15 PM   #6
Rewards Points: 1,214
Plywood.
COLDIRON is offline   Reply With Quote
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
It is hard to find 1/2 t and G plywood so would regular plywood be ok ? dewi Flooring 14 05-04-2010 01:05 PM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 07:47 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
