Osb - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2012, 07:51 PM   #1
Osb
Got a curious question here...
what is the deal with the odd sizes for OSB?
7/16 is obviously cheaper than 19/32, but is there a big enough difference between the two to select the 19/32?
what is up with the size, 19/32.......i don't get it.
i put a sub floor in my attic above my garage and used 19/32 (mostly because i didn't see that Lowe's sold 7/16.
would any of you selected the 7/16 over 19/32 for a sub floor above your garage? also, is there a significant difference in its weight.
i tried to find information concerning their weight, strength and such.
sorry for the ramble, but i am second guessing my choice of 19/32 and am somewhat concerned about the extra weight in my ceiling in my garage.
rwreuter is offline   Reply With Quote
Old 01-01-2012, 08:35 PM   #2
MarginallyQualified
Rewards Points: 2,464
5/8" = 10/16" = 20/32" <-- right?
A surface layer of Tyvek (or other/similar) is how thick?
Lets call it 1/32" OK? 20/32-1/32 = what?
would any of you selected the 7/16 over 19/32 for a sub floor...?
I wouldn't have gone any thinner than 19/32"
hth
Old 01-02-2012, 12:54 AM   #3
Registered User
Rewards Points: 4,894
The 7/16" is only for floor joists 16" on center, the other is for 16, 20, 24" o.c.: http://webcache.googleusercontent.co...ient=firefox-a
Gary
The Following 3 Users Say Thank You to Gary in WA For This Useful Post:
ben's plumbing (01-02-2012), mae-ling (01-02-2012), rwreuter (01-02-2012)
Old 01-02-2012, 09:34 AM   #4
Gary
Thanks for the info!!! Best i have read so far.
Old 01-02-2012, 12:58 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
if its for a floor i wouldnt be using either, id be using 11/16"s. its actually designed to use as a sublfoorm 7/16 and 19/32 are for wall sheathing and roof sheathing
woodworkbykirk is online now   Reply With Quote
Old 01-02-2012, 03:58 PM   #6
Rewards Points: 1,092
Not to divert too much, but why IS OSB material made in odd dimensions? Is 7/16 the "strength equivalent" of 1/2" ply, etc, or has 1/2" ply been tweaked down, too? It sure would be nice to have uniformity in dimensions. I also think that "2 by" material should be the full 2" x 6", etc; let the rough cut vary, as it does anyway. But, that is a dream....
Old 01-02-2012, 06:48 PM   #7
even if it is for a floor in an attic above a garage which will only be used for storage?
Old 01-02-2012, 07:49 PM   #8
Framing Contractor
Gary
Gary,
Who uses 7/16 on top of floor joists?
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
woodworkbykirk (01-02-2012)
Old 01-02-2012, 08:01 PM   #9
Registered User
The site was "printed in Canada"........ I didn't write the article.
Not me, I wouldn't use it for sheathing, or firewood.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 01-02-2012, 08:23 PM   #10
Rewards Points: 123
Once upon a time, you could go into a hardware store and buy 3/4" plywood. Now you have to get 23/32". Was there some remarkable only recently discovered technical innovation? I say no. My suspicion is too many lawyers. A few years back 3M company was successfully sued by the State of California for tens of millions of dollars because the 1" cellophane tape the state was buying was only 0.9 something inches wide. Now there is no 1" tape. Just undimensioned tape. Why should a lawyer have to understand that a dimension always implies some real tolerance when they can make millions on the minus tolerance? Feel lucky that they still provide any thickness measurements at all. The companies could have protected themselves from lawsharks by identifying different thicknesses with names (4x8 foot sheet of Ralph) and letting the buyers figure out what Ralph corresponds to.
mwpiper is offline   Reply With Quote
Old 01-02-2012, 09:58 PM   #11
what?????? that last post is pointless.
the reason for 11 /16" and the like is more do to how dense the wood is now .. it gets pressed tighter,, but anyhow.. i would never use 7/16" for floor subfloor.. 7/16 fir plywood as underlay yes.. which goes over top of subfloor
Old 01-02-2012, 11:39 PM   #12
Just a DIY guy
We used 1/2 inch or 15/32 in my garage attic, primarily due to weight, but it's plenty sturdy for light storage, even with 24" oc joists. It's not solid like a real floor, but enough for the use. Maybe it was 7/16, I didn't put it in, my contractor did, and he said it was 1/2 (which we know does not exist).
I am building a similar floor in my house attic with 19/32 tongue and groove SturdiFloor, again with 24" oc joists, and the one 4x8 sheet that is fully screwed down feels very solid. again it will be for storage. A "real" floor should have 3/4 or 1 inch subfloor, IMO.
M3 Pete is offline   Reply With Quote
