Old 02-02-2012, 03:35 PM   #1
options for raising floor on enclosed patio?
I have a patio that was enclosed and made part of the house by previous owner. I want to demolish the patio and build this area as an addition to the house, with permits, with the floor level with the rest of the house. Right now the patio area is on a cement slab, a step down about 10 inches lower than the house floor.
What are some methdods for raising a floor, making it level with the rest of the house? I want to do some research before calling an architect or contractor.
what-do-i-do is online now   Reply With Quote
Old 02-02-2012, 05:58 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Pressure treated lumber used on top of the slab, with a barrier as a thermal break, such as foam board and plywood. What does your permit office state as to your idea on this?
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 02-02-2012, 08:36 PM   #3
You may be facing a new foundation pour. In most locals it's a requirement that the foundation top be 6" above grade. Also, you can't transfer weight directly to the slab without a foundation beneath.
Check to see if the slab has a proper foundation that will pass inspection for inhabited space. If it does, you should be able to block up or pour to get the right height and set anchor bolts. Then I would proceed as with any standard addition construction. Anchored sealed sill, rim joist, joist on joist hangers, deck, walls, etc and treat the area below as a crawl.
If you find, that the patio slab is just a slab without a footer, you're in for some excavation.
Let us know what you find.
RenoStruct is offline   Reply With Quote
Old 02-02-2012, 08:54 PM   #4
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Is the house itself on a raised foundation?
Andy.
AndyGump is offline   Reply With Quote
Old 02-02-2012, 11:23 PM   #5
Andy.
house is on raised foundation, got a crawl space.
Old 02-02-2012, 11:27 PM   #6
AndyGump's Avatar
So demo the slab to make room for the new addition on a raised foundation like the original but up to present code.
You will have to excavate a little to get the proper depth for code, I design this kind of thing all the time. It is what I am best at.
Andy.
Old 02-02-2012, 11:46 PM   #7
Originally Posted by AndyGump View Post
So demo the new addition on a raised foundation like the original but up to present code.
Andy.
I'm a little confused about your use of "demo."
Any word on the slab footer?
Old 02-03-2012, 01:48 AM   #8
AndyGump's Avatar
Thanks, changed it.
Andy.
Residential Drafter/Designer
Old 02-03-2012, 02:35 AM   #9
Retired carpenter
A friend of mine did the same in his house. The city wanted him to redo the whole thing, like Andy suggests. He hired an engineer who took a few measurements and designed what Gregzoll mentioned: a pressure-treated lumber deck above the concrete pad. The city accepted the engineer's design, and my friend saved himself a lot of money by not tearing out a concrete pad and replacing it with a concrete wall.
abracaboom is offline   Reply With Quote
Old 02-03-2012, 02:48 AM   #10
AndyGump's Avatar
Here in CA. he needs 18" min. under a raised foundation for access anyway. Lots of good reasons to demo the pad.
It just isn't that big a deal.
Andy.
eyebrow arch on enclosed stucco patio stobin Building & Construction 2 01-31-2011 05:33 PM
Should I open up my enclosed patio? diyimk Building & Construction 4 07-14-2008 01:38 AM
Constructing an enclosed patio press Building & Construction 2 01-16-2008 05:07 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
