Options To Attatch Shower Curtain Rod/etc. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 12:28 PM   #1
Rewards Points: 77
Options to attatch shower curtain rod/etc.
was looking for any other ideas or options to attatch shower curtain rod and tp holder to porcelain tile other then using the screws. i dont have diamond drill bits and they cost 50.00 at lowes. so before i do buy them is there any adhesives that are good to use? am i better to use the screws?
thanks!!
bryan1282 is offline   Reply With Quote
Old 10-13-2011, 01:57 PM   #2
yummy mummy's Avatar
Rewards Points: 1,016
I had the same problem when I wanted to install a shower curtain.
I did purchase a rod, that has springs in it, and it adjusts to the walls. Should be able to find it at Lowes.
For TP holder, there are holders that stand upright and you just add the paper. You don't have to drill any hole whatsoever.
Good Luck
yummy mummy is offline   Reply With Quote
Old 10-14-2011, 10:27 AM   #3
get shower doors
showerdoorsnyc.com
pawel is offline   Reply With Quote
Old 10-14-2011, 10:44 AM   #4
MikeKy55's Avatar
Rewards Points: 254
Good Luck
MikeKy55 is offline   Reply With Quote
Old 10-14-2011, 11:21 AM   #5
Rewards Points: 77
i already have a double curved shower rod and cant use doors cuz its an air tub and has the control panel on that side. cant use the tp holder that sits on the floor cuz wife says its ugly....lol. i guess im buying a diamond drill but huh?? oh well, i spent a ton of money already on the bathroom, whats another 50 bucks or so.
DIY Shower curtain rod assembly for a clawfoot tub ejcate Plumbing 4 10-04-2016 06:46 AM
Tub leaking past shower curtain Outbacker Plumbing 8 12-10-2010 05:15 PM
Flat plastic curtain for shower window VersaBar General DIY Discussions 8 12-01-2010 05:14 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Shower pan/base options JeepCop Plumbing 1 01-07-2007 06:01 PM
