Old 07-28-2008, 11:06 AM   #1
Is this an optical illusion?
My husband still wants to buy this house to fix up and sell or rent. I keep looking at the photos I took and I am sure there are major problems. Something is crooked I think, or could this be an optical illusion?
At first I just thought the roof on the left side of the front of the house was slanted. Now I think the whole house is slanted. What is weird is the two story part of the house looks like it is slanted to the left from the front, but from the back it looks like it is slanting the other direction (away from the house). I didn't notice any of this while I was there. Only after looking at the photos. Could it be that the siding is all screwed up and it is causing me to see things?
I know I should go out there again with a level and ladder and really see what is going on with this house.
So, if I drive out there and find out something is not level, is this something that would make a home unfixable? Or at least too costly to fix for a profit.
clueless88 is offline   Reply With Quote
Old 07-28-2008, 12:38 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
What I would do is go back with a level and check the walls and floor of the interior of the house. the siding looks as if it has been up for a few years. the siding installer could of started the siding by measuring off the soffit on either side of the house. so it appears level with the windows and door. As far as the side addition it appears as tho the rafters or the rafter tails where cut longer as they get closer to the main house. or the outside walls could of spread. BOB
Old 07-28-2008, 01:25 PM   #3
Yoyizit's Avatar
Standing across the street from the house, the farther the better, set up a level on something so it's parallel to the roof ridge and confirm that the bubble is centered.
Then from a few feet in back of the level, sight along the top of the level until the roof lines up with the top of the level, from left to right.
The roof line should then be parallel with the top surface of the level.
And if the roof looks like it's sagging in the middle, all you need to confirm/disprove this idea is a straightedge (a credit card, a ruler). Use the same sighting rules.
For sagging, you can even use a straightedge on a photo.
These methods have some optical problems of their own, but I think it's very likely that they will cancel out illusions, if that's what's happening here.
If you ever want to sell the house you may have to convince the buyer using the same methods, and you should be the one to bring up "this illusion thing."
Please lemme' know what finally happened.
More On This Topic
Don't just watch Star Wars; power yourself through the galaxy with fiber optic television--or FIOS TV. FIOS makes all the difference between a bland image on your screen to television reception that takes looks like you're looking at the real thing. From... Read More »
Optical illusions are fun, interesting and a great way to liven up a party. People of all ages seem to enjoy seeing them. Trying to figure out how an optical illusion works makes for great conversation. You can use a photo editor program and your... Read More »
So after we’ve kind of come up with an idea of colors that the client likes or that you like yourself out of your artwork, one of the things that I like to do is go to the paint store and buy paint chips and then create a diagram of the space. It... Read More »
Hi, I am Kinsey Snyder on behalf of Expert Village. In this clip we are going to talk about fixing and repairing ball marks. I have just hit my approach shot into the green here, as you can see by the ball mark here. Nothing infuriates golfers to have a... Read More »
Hi, this is Jeremy, with Expert Village. I'm going to go ahead and talk to you a little bit more about what you can do with your contact juggling. The next thing I'm going to teach you is the "thumb hold", which you use when you do a floating ball trick... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
