Opening A Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 10:24 AM   #1
Opening a wall
I would like to open up part of an interior top floor wall to turn a bedroom into a loft. The wall spans 16 feet. At either end the height is 4 feet 6 inches and rises to 8 feet 1 inch over a span of 5 feet. The remaining 6 feet is the area I want to open up.
My home was built in 1900. I popped my head into the attic above and took note that the beams run perpendicular to the wall.
The current framing of the wall does not indicate this is a load bearing wall. There are no support studs directly under where I believe the beams rest.
My plan is to construct a header to span across the 6 foot opening. This would be constructed of 2 - 2 x 6 with 1/2 inch plywood sandwiched between. Then add a 2 x 4 bottom plate. I would install (2 - 2 x 4's each side) king studs at the points where the roof changes from slanted to flat. Then use jack studs (1 - 2 x 4 each side) to support the header. Does this sound correct?
kmgilbertson is offline   Reply With Quote
Old 12-22-2011, 10:49 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Never mind.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-22-2011, 11:58 AM   #3
Originally Posted by titanoman View Post
Never mind.
Never mind what?
Old 12-22-2011, 12:02 PM   #4
Disabled wood vet
titanoman's Avatar
Originally Posted by kmgilbertson View Post
Never mind what?
I started to ask questions about why the 2x6's and got busy. I'll go back and read your post again right now.
I see. I think you have it figured out. I don't see what I would tell you to do different.
The Following User Says Thank You to titanoman For This Useful Post:
kmgilbertson (12-22-2011)
Old 12-22-2011, 12:45 PM   #5
Thank you for your input. I have photos of the wall but am not sure how to upload them (if that's at all possible)
Old 12-22-2011, 12:49 PM   #6
https://www.facebook.com/photo.php?f...type=3&theater
Old 12-22-2011, 12:50 PM   #7
That is wallpaper on the ceiling .. not water damage.
Old 12-22-2011, 07:35 PM   #8
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
If it is not a load bearing wall you could get away with just one 2x4 on the flat for a "header".
Andy.
AndyGump is offline   Reply With Quote
creating an opening bearing or not? Wiscbldr Building & Construction 2 11-01-2010 02:32 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
New opening in masonry wall Jeepsail Building & Construction 2 01-17-2010 02:50 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
opening through party wall arise Building & Construction 13 02-16-2007 04:33 PM
