Old 03-06-2010, 12:47 PM   #1
Opening basement stairwell?
I'm remodeling my basement and contemplating opening up one side of the stairwell leading into the basement. There is nothing I can see that would indicate that the stairwell wall is load bearing but wanted to make sure. Here are some pictures of the section I'm thinking of removing and what is directly above it. Am I right in thinking this isn't bearing any load? I'm thinking that since it's running parallel to the joists and the fact that the joists are doubled up over the stairwell that it wouldn't be bearing any load? Also, I'm almost positive that the stairwell wasn't put in until after all the framing was complete (almost positive that is )
Thanks for looking and any input you can provide. I just want to make sure I'm not missing something.
Here are the pictures:
barlav is offline   Reply With Quote
Old 03-06-2010, 09:39 PM   #2
Super Moderator
The basement sections are not load bearing and can be removed.
The main floor sections also appear to be partitions--HOWEVER ---Please have some one knowledgeable do a site inspection--Either a framing carpenter or engineer. Best to be safe--after all I'm just some stranger on the internet!!!
--Mike--
Old 03-07-2010, 01:56 PM   #3
Thanks Mike.
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
How best to dehumidify basement? peleliu HVAC 0 07-27-2009 10:55 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
