Open Web Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 09:56 AM   #1
Rewards Points: 121
Is there any difference in the strength of open web floor joist with 4x2 or 2x4 construction of the webs, that is the members with the long dimension being either horizontal or vertical? I understand the 4x2 orientation gives more interior space within the truss but is this at the expense of strength.
jrepp44 is offline   Reply With Quote
Old 01-20-2010, 11:08 AM   #2
Floor trusses are made with load limits in mind. If there is a higher anticipated load than what would be considered standard, the truss design will be modified sufficiently to accommodate the additional load. Whether or not the individual members are oriented 4x2 or 2x4 is negligible. The strength of the the truss has been calculated and deemed sufficiently rigid for the application. That being said, what is it that you are trying to accomplish? With more specific details, a more specific answer can be given.
CustomBuild is offline   Reply With Quote
Open Stairs in Basement ngerhard Building & Construction 4 07-10-2009 06:30 PM
Which should open first GFCI or breaker jamiedolan Electrical 14 01-19-2009 03:03 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
garage door open light deck hand Electrical 3 01-22-2008 08:29 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
