Open Up Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 07:42 PM   #1
Open up wall?
Hi Guys,
Long time lurker, first time poster. I must say, I love this forum!
Anyway, I need some advice before I go on and do something stupid. I want to open up old closet in the basement I'm converting.
I would like to figure out if the wall is load bearing.
This is the closet: http://i.imgur.com/R2OADh.jpg
To the right of the closet is the door to the laundry room. This is what it looks like: http://i.imgur.com/kRNxRh.jpg and http://i.imgur.com/0x2M2h.jpg
The ceiling joists are parallel to the wall. And I only want to open it a few inches on each side. What do you think?
Thanks for the help!
usuariofeliz is offline   Reply With Quote
Old 06-06-2012, 07:48 PM   #2
A bearing wall would not run parallel to your joists,so I think you are good to go.
IntexInspector is offline   Reply With Quote
Old 06-06-2012, 07:52 PM   #3
I also noticed that you have a vinyl dryer exhaust duct, I would replace that with a rigid metal and I would do it yesterday
Old 06-06-2012, 07:59 PM   #4
Thanks! For some reason it comes out of the dryer as one of those flexible metal ones, then vinyl, then what you see on the pic. I'll change it asap.
Old 06-06-2012, 09:13 PM   #5
Framing Contractor
That's not true at all! I've framed many houses and additions where a parallel wall can be a bearing wall support a bearing wall or roof above. You obviously haven't framed much to make a statement like that.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-06-2012, 09:19 PM   #6
AHH, SPANS!!!
Rewards Points: 1,166
in the area where you took the 2nd and 3rd pics hop on a step ladder and point a flashlight up in the joist cavity and shine it back toward the wall you want to remodel. if there is anything heavy sitting on it you will see.also, it looks like the joists land around the wall and not on it, with the flashlight you should see blocking that goes from one joist to the other joist and the top of the wall ties into that blocking.
hand drive is offline   Reply With Quote
Old 06-06-2012, 09:23 PM   #7
I have never seen a parallel bearing wall in a basement before, I have been renovating for 15 years , perhaps I will see one in the next 15 years
Old 06-06-2012, 09:36 PM   #8
AHH, SPANS!!!
I've seen them added in ( by me!)to handle new loads for multiple floors above along with footings of course.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Advise: Cutting open an exterior wall for a new door Turk80 Building & Construction 5 11-01-2009 09:25 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
