Open Rafter Tail Trim Out And Ventilation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 09:08 PM   #1
Question
Open rafter tail trim out and ventilation
Hi,
I am building a new home with open rafter tails and am looking for some ideas around triming out the space between the rafter tails. I am using brick veneer and hardy plank, the trim would finish out from the top of the veneer and the space between the rafters. I don some searching and found a product called Cor-a-vent, but it only comes in black and white.
Would like to make it custom. Any pctures would be great.
Thanks in advance
Nutchie
Nutchie is offline   Reply With Quote
Old 06-23-2012, 07:38 PM   #2
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
You could use a series of 11" hardy planks and an aluminum soffet vent. It means cutting a hole in that stuff and it dulls the blades and makes a shed load of dust.
http://www.homedepot.com/buy/buildin...ite-21355.html
Paint the vents with spray paint any color
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 06-23-2012, 07:54 PM   #3
What part of the country are you in? Only time I've ever seen a house with open rafter tails with no fascia , a pressure block was required between the rafters. Just curious.
CopperClad is offline   Reply With Quote
The Following User Says Thank You to CopperClad For This Useful Post:
Tom Struble (06-23-2012)
Old 06-23-2012, 09:49 PM   #4
Open rafter tails
I'm in south Louisiana. As far as I know there are no codes to govern this here. Any ideas are welcome.
Old 06-23-2012, 09:53 PM   #5
Uh.. Is this house built already? Pretty sure you have hurricane force winds there and a pressure block would absolutely be required, as well as probably 2 A35 clips and minimum a H1 clip on the rafter. You can however still have vent holes in the pressure block, and still do whatever kind of vented soffit you want.. Is the home in the design phase?
