Ontario Building Code? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 01:09 PM   #1
Ontario building code?
Does anyone from Toronto, Ontario, Canada know a place that you can rent the building code book? I don't want to spent $150 to buy it just to writ the test. Thanks
jak ali is offline   Reply With Quote
Old 10-09-2012, 01:43 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
can't speak for Canada, but in the states a lot of libraries have code books that you can check out, worth a check
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-09-2012, 04:39 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
what test? most code tests they have to provide you with a copy. its not to see if you know the code. but to see if you know how to look things up in it. thats how it is for the I.P exam for trademan writing for their red seal
woodworkbykirk is offline   Reply With Quote
Old 10-09-2012, 06:07 PM   #4
GBrackins, here in Toronto, we're not allowed to check it out, it's "Reference Only."
woodworkbykirk, it's for a MMAH certificate (Ministry of Municipal Affairs and Housing) which you take a course and writ the exam in a college in my case Humber College, where we have to have our own book
Old 10-09-2012, 06:39 PM   #5
Rewards Points: 558
You can go to your local libraries. Can’t say they will be up to date though….
epson is offline   Reply With Quote
Old 10-09-2012, 06:42 PM   #6
Rewards Points: 558
I went to Humber and had to buy the book so we could use it in class and have open book exam with it.
Old 10-09-2012, 06:54 PM   #7
[quote=jak ali;1027340]Does anyone from Toronto, Ontario, Canada know a place that you can rent the building code book? I don't want to spent $150 to buy it just to writ the test. Thanks[/quote
Humber has a used book store. I'm pretty sure most uni's and college's too do.
Also you may want to give these guys a try
http://www.campusbooks4less.com/collegebookstores/
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
jak ali (10-10-2012)
Old 10-09-2012, 07:16 PM   #8
if they expect you to provide the book its a sham.. unless its something you will have to be referring to constantly which may be the case
for myself im a licensed carpenter who works in high end renos`, were constantly running into code things, most often though the engineer or architect specs things for us.. sometimes the architects specs aren`t up to snuff in that case the engineer specs something better. rarely is it do to inspectors though
Old 10-09-2012, 07:29 PM   #9
Rewards Points: 558
It all depends on what class you’re taking; my class required the purchase of the OBC because we constantly used it for reference and would have open book tests and exams.
Old 10-09-2012, 09:41 PM   #10
you can view it online here at http://www.e-laws.gov.on.ca/html/reg...s_060350_e.htm trust me i spent all day trying to find out something for myself.
Jeff9377 is offline   Reply With Quote
The Following User Says Thank You to Jeff9377 For This Useful Post:
Old 10-10-2012, 03:14 PM   #11
you still need yours? u wanna sell it or rent it untill the end of November? tried to send an email but couldn't find it
Old 10-11-2012, 10:49 PM   #12
Rewards Points: 558
Man it’s been a lot of years and I have to see if I still have it around somewhere. If I do, it won’t be up to date.
GFCI requirement in Ontario Electrical Safety Code lameon Electrical 15 01-20-2015 07:51 PM
building code and sheds WillK Building & Construction 4 06-18-2011 01:25 AM
Question regarding bonding wires - Ontario Code? jim.thornton Electrical 6 08-17-2010 09:23 AM
Simplified/Summary CA Building Code? acerunner General DIY Discussions 5 03-18-2010 10:46 PM
Bathroom Fan - Do Insulated Exhaust Ducts Meet California Building Code? fritzycat1 HVAC 1 06-20-2009 03:29 PM
