-   -   Ontario building code? (http://www.diychatroom.com/f19/ontario-building-code-159531/)
jak ali 10-09-2012 01:09 PM
Does anyone from Toronto, Ontario, Canada know a place that you can rent the building code book? I don't want to spent $150 to buy it just to writ the test. Thanks
GBrackins 10-09-2012 01:43 PM
can't speak for Canada, but in the states a lot of libraries have code books that you can check out, worth a check
woodworkbykirk 10-09-2012 04:39 PM
what test? most code tests they have to provide you with a copy. its not to see if you know the code. but to see if you know how to look things up in it. thats how it is for the I.P exam for trademan writing for their red seal
jak ali 10-09-2012 06:07 PM
GBrackins, here in Toronto, we're not allowed to check it out, it's "Reference Only."
woodworkbykirk, it's for a MMAH certificate (Ministry of Municipal Affairs and Housing) which you take a course and writ the exam in a college in my case Humber College, where we have to have our own book
epson 10-09-2012 06:39 PM
You can go to your local libraries. Canít say they will be up to date thoughÖ.
epson 10-09-2012 06:42 PM
I went to Humber and had to buy the book so we could use it in class and have open book exam with it.
creeper 10-09-2012 06:54 PM
[quote=jak ali;1027340]Does anyone from Toronto, Ontario, Canada know a place that you can rent the building code book? I don't want to spent $150 to buy it just to writ the test. Thanks[/quote
Humber has a used book store. I'm pretty sure most uni's and college's too do.
Also you may want to give these guys a try
http://www.campusbooks4less.com/collegebookstores/
woodworkbykirk 10-09-2012 07:16 PM
if they expect you to provide the book its a sham.. unless its something you will have to be referring to constantly which may be the case
for myself im a licensed carpenter who works in high end renos`, were constantly running into code things, most often though the engineer or architect specs things for us.. sometimes the architects specs aren`t up to snuff in that case the engineer specs something better. rarely is it do to inspectors though
epson 10-09-2012 07:29 PM
It all depends on what class youíre taking; my class required the purchase of the OBC because we constantly used it for reference and would have open book tests and exams.
Jeff9377 10-09-2012 09:41 PM
you can view it online here at http://www.e-laws.gov.on.ca/html/reg...s_060350_e.htm trust me i spent all day trying to find out something for myself.
jak ali 10-10-2012 03:14 PM
you still need yours? u wanna sell it or rent it untill the end of November? tried to send an email but couldn't find it
epson 10-11-2012 10:49 PM
Man itís been a lot of years and I have to see if I still have it around somewhere. If I do, it wonít be up to date.
