#1 |
One more vinyl siding question
You guys have been extremely helpful with the siding so far!
One big issue. We bought windows with the integrated J channel. It's supposed to be 3/4, I think - but the 3/4 siding fits VERY tightly into it...I figure this can't be good... I can push it in and move it, but it's very tight...Crestline 200 windows. Any thoughts? Andrew |
#2 |
no one has experience with this, I guess....
I've tried calling the window manufacturer, and they say their channel is 3/4, so I guess it's ok... |
#3 |
Architectural Designer
If you can move it around by hand I don't think you'll have problems...
Life's too short...so enjoy it! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
I can move it by pulling really hard on it...it's not easy, but it's not permanently stuck in there...
#5 |
Just talked to the window makers - the manufacturer of the windows says it's 3/4 channel, but I measured it to be 5/8...that eighth of an inch is a big deal, as it turns out - it's ratehr tight...
I guess I'll just have to squeeze it in and hope for the best? |
#6 | |
One more vinyl siding questionQuote:
1) getting the manufacturer out there and arguing for replacement window 2) cutting off the j-channel face, sanding smooth, and going with the siding system j-channel 3) possible heating the casing and deforming it to give a wider throat
#7 |
"Nail-Bender"
If the siding is "snug" from the back of the panel to the face -
you shouldn't have any problems. Usually, the expansion/contraction problems occur, along the length of the panel. Speaking from hundreds of vinyl, siding repairs. rossfingal Happy Holidays! |
| Display Modes | |
| Vinyl siding over lap siding | thunderhead | Carpentry | 5 | 06-08-2011 11:56 PM |
| osb vinyl siding question | jjjeno | Building & Construction | 2 | 04-16-2011 09:01 PM |
| Storing Vinyl siding in attic? Deform? | rebar | Building & Construction | 2 | 08-18-2010 11:15 AM |
| Replacing Wood Siding WIth Foam Backed Vinyl | xludan | Building & Construction | 1 | 05-21-2009 07:27 PM |
| Sealing windows with vinyl siding | bighoneydolist | Building & Construction | 8 | 03-08-2009 07:36 PM |
