One More Soundproofing Question... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 03:16 PM   #1
Rewards Points: 150
One more Soundproofing Question...
I am about to complete an addition with a staggered wall, which will receive double drywall, GG and sound acoustic sealant. I purposely bought extra GG for various areas where I will be wanting to dampen sound. A few of these areas have drywall with the older style of large texturing (not popcorn...).
If I install 5/8" drywall with GG over these walls that have the texture, will there be an impact on the effectiveness of the soundproofing, since the texture will prevent flush placement?
rightit is offline   Reply With Quote
Old 02-29-2012, 08:13 AM   #2
Soundproofing Guy
Rewards Points: 158
Good question. If the texture is light, you're fine. If heavy popcorn or texture, you'll have to knock down the peaks. You might try spraying some warm water to see if it budges. If you feel you need to.
Ted White is offline   Reply With Quote
Old 03-08-2012, 02:19 PM   #3
Rewards Points: 150
Hi Ted.
Apologies for the delayed response. I have one section that the texture is a bit high, so I'll be scraping that down.
Thanks for all of your input in this and other threads. Your knowledgeable advice is greatly appreciated.
Mark
Old 03-08-2012, 02:20 PM   #4
Soundproofing Guy
Rewards Points: 158
Sounds good!
Old 03-11-2012, 08:22 PM   #5
Rewards Points: 150
Hello again, Ted. Another question (somebody stop me... ):
The staggered stud wall mentioned in my OP...would it be of any benefit to run a bead of SilenSeal caulking on the studs prior to sheet placement?
Again, thank you.
Old 03-13-2012, 09:33 AM   #6
Soundproofing Guy
Rewards Points: 158
That's also a good question. There's no benefit.
The Following User Says Thank You to Ted White For This Useful Post:
rightit (03-13-2012)
Old 03-13-2012, 09:45 AM   #7
Rewards Points: 150
Thanks!
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
soundproofing question - apartment challenge josefismael Remodeling 3 07-25-2009 07:59 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
