One More Insuation Thread - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 09:07 PM   #1
Rewards Points: 211
Another Insulation Thread
Hello,
I am slowly working towards insulating and fixing the ductwork and parts of the walls around my place (a condo unit whose basement is primary made out of concrete block, and the first and seconds floors out of bricks). There are lots of lapses, gaps, and opening in the aluminum ductwork (the place was reformed and remodeled, but the jobs in many ways wasn't well done at all...) and parts on the upper portion of the walls whereon one can even feel air stream. Trying to use ductwork sealant compound/putty to fill small irregularities and crevices and aluminum foil tape, and also a combination of fiberglass ductwork insulation (the one that is wrapped around the ductwork) and reflectix over it in order to create a double layer of insulation (not sure how much improvement one could get out of that setup).
Ductwork sealant filling irregularities and crevices:
http://farm2.static.flickr.com/1133/5135950899_501f689341.jpg
Old thin fiberglass ductwork insulation and new reflectix insulation applied to ductwork:
http://farm5.static.flickr.com/4031/5137223390_48dd136c95.jpg
Fiberglass, Reflectix and Great Stuff foam combined on uninsulated part of walls:
http://farm5.static.flickr.com/4055/5150117958_0927e1b8be.jpg
http://farm5.static.flickr.com/4153/5096343323_5f1895eb96.jpg
http://farm5.static.flickr.com/4049/5150117968_a5efa888cf.jpg
http://farm2.static.flickr.com/1158/5150117970_468b0660bc.jpg
New fiberglass ductwork insulation (thick one) applied on ductwork, and I am considering adding an extra layer of insulation on top of it with reflectix:
http://farm2.static.flickr.com/1346/5148918859_e96b8d90e6.jpg
http://farm2.static.flickr.com/1147/...b9d486d234.jpg
Any help and comments would be appreciated.
tk
tk3000 is offline   Reply With Quote
Need help:how to install false stair thread vluzhko Flooring 5 05-10-2010 08:13 PM
How to Subscribe to a Thread brokenknee How To Guides 1 01-25-2010 08:37 AM
