Old Window Header Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2008, 05:25 PM   #1
Question
Old window header construction
on older homes why did they take two 2x4's and lay them flat above a window for the header on a bearing wall?
Theresa is offline   Reply With Quote
Old 10-30-2008, 10:01 PM   #2
They didn't know any better.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-30-2008, 10:07 PM   #3
old construction window headers
that many people didnt know any better?
I would like to give them more credit but I cant find any
Thanks for the affirmation.
Theresa
Old 10-31-2008, 06:31 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
A lot of those houses had 3/4 thick solid wood sheathing to tie the window headers and top plates together. That helped to bear the load (right or wrong). A good number of them were balloon construction too. Plenty of houses were built that way and never had sag issues over the windows. Many construction techniques evolved from from when houses were built of much more massive stock. The same techniques were carried over into the later era when we started building houses out of kindling wood. Just how construction has evolved.
Old 10-31-2008, 11:45 AM   #5
Drywall contractor
Rewards Points: 1,070
They did it because they could.........and it was the accepted way at the time. As Maintenance6 pointed out, it was also a time when a 2"x4" WAS 2"x4" (at least) and stouter sheathing. Not to mention that the lumber itself was stronger! Not like today where it's planted, fertilized, grown for 15 (not 50) years, and harvested. Then it's milled, kiln dried and shipped out. Hence, you take the banding off a bundle of 2"x's and half of them warp before you can use them. It was a different era in building.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-03-2008, 02:57 PM   #6
They didnt save any money by doing it that way.
I always remembered windows were never easy to open on old homes.
Aside from the fact that , they painted them shut. The construction
may have contributed to that.
I just always wondered why. Still nobody knows.
Thanks for the replys ... really no one can really imagine why.
Our wood quality got worse but we got smarter.
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
RO size vs. window unit size, new construction BigJimmy Building & Construction 3 01-02-2008 07:34 AM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 04:15 PM
Framing for a new construction window sandyman720 Building & Construction 2 05-31-2007 12:54 PM
Replacement window as new construction mt232 Building & Construction 2 03-23-2007 11:18 AM
