Old Stone Foundation Repair - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 01:50 PM   #16
Oh yeah... I meant to come back and give a final update. The lime mortar took a bit longer to dry (it was also pouring rain that week so the basement walls were damp). But once it dried it was nice and hard. It is a bit softer than the quickcrete mortar, but I guess that's the point. Good luck with your pointing.
Nivk is offline   Reply With Quote
Old 08-26-2011, 10:30 AM   #17
Mr. Scarborough,
I have a quick question for you. You said: "For a blended mortar, you can use Type S lime straight from the bag, for lime mortar, the lime needs to be hydrated. Gently cover with water and keep covered with water for at least 2 days, then pour off (and save) excess water and the lime is ready to be used. As long as you keep it covered with water it will remain in a usable condition."
I plan to use as you recommend up to 10% portland to help with an initial set. Is this considered a "blended mortar" ? The lime at the Home Depot in my area is Type S hydrated. Is this different than placing lime in a bucket for several days with water?
I've got a big project and am completely new to this. Thanks for you advice.
tarzanbites is offline   Reply With Quote
Old 02-02-2012, 10:08 PM   #18
Is that all it takes to get hydrated lime? I've been working for years in France (where i learned the masonry trade), and I got back to the states expecting to be able to find NHL-3,5 but it's damn near impossible.
Originally Posted by Tscarborough View Post
It is acceptable to mix 1 part lime and 3-5 parts sand (by volume, always by volume).
For a blended mortar, you can use Type S lime straight from the bag, for lime mortar, the lime needs to be hydrated. Gently cover with water and keep covered with water for at least 2 days, then pour off (and save) excess water and the lime is ready to be used. As long as you keep it covered with water it will remain in a usable condition. It is extremely caustic when wet, so wear protection.
SimonFromKansas is offline   Reply With Quote
Old 09-04-2014, 06:18 PM   #19
old stone building
I too need to find out what type of cement to use to repair my old stone home I purchase last year. The stones in the basement/foundation is turning to powder. I need something that does not absorb water. Can I order this type of cement/mortar?
NHughes is offline   Reply With Quote
Old 10-26-2014, 01:20 PM   #20
Rewards Points: 2
so what is the bottom line ...I have a 1850 cape in Mass very wet most of the old lime mix is gone with large gaps in a 6 foot high field stone foundation still working on gutters and french drains to help with the water problem ....over the years the stone has been moving a bit ...house is on side of hill facing down.
the old restore guys seem to say lime mix "This OldHouse" says S mix with Bonding additive
is there a common agreement here ....help I want to start soon
GREAT CHAT !!!
elwoodzulu is offline   Reply With Quote
Old 02-12-2016, 02:18 PM   #21
Rewards Points: 2
I have an 1870's rock home located in Mason, TX. I have removed all plaster, etc and only rock and lime motar remain. What should be my next step. One person has said to pressure wash it, one said never do that just do an acid rinse.
I also want to remortar or tuck point this rock, what method or mixture should I use?
Any thoughts greatly appreciated.
Thank you!
Rock house lady is offline   Reply With Quote
Old 02-12-2016, 02:33 PM   #22
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Thank you!
Ayuh,.... Welcome Aboard Rock house lady,...
You'll find you'll get more, 'n better answers to yer question, if ya start a New thread of yer own, insteada hy-jackin' this couple year old, 2 page long thread,....
Most folks start at post #1, read through, 'n answer previous questions, never gettin' to yer's,...
On the Building & Construction forum page, at the upper left corner of the page is a yellow button that says, ,....
Click there, 'n tell yer story like ya did here,.....
Everybody will see it, 'n be glad to give ya some answers,....
Personally, Pictures would help, 'n be careful with the acid, dilute it proper, 'n neutralize/ rinse it well,....
Good Luck,....
Tags
basement , foundation , mortar
How to scew into stone foundation? Kacavich Building & Construction 7 09-23-2013 12:48 AM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 01:27 PM
moist soil under raised foundation during winter bn300 Building & Construction 0 09-17-2010 03:51 AM
Thinstone on sheathing 3/4" off of the foundation Kasper Building & Construction 3 08-27-2010 09:57 AM
Pointing a stone foundation bilbobroberts Building & Construction 2 07-19-2009 11:50 AM
