Old Siding Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 10:42 PM   #1
SFX Group's Avatar
Send a message via MSN to SFX Group Send a message via Skype™ to SFX Group
Question
Old siding replacement
Hi
House has siding that’s some sort of hard Vinyl / plastic (i did say metal orginally), its very plain in design, about 8 inches high, just a flat surface that overlap. Has separate corners (will get picture).
We think fitted early to mid 1980's, any idea if there is a replacement as certain parts need to be replaced and a chimney is being removed so needs new parts put in.
Dont really want to replace the whole siding yet...
Many Thanks
Ashley
© Copyright 2011 - www.ashleygriffin.ca
SFX Group is offline   Reply With Quote
Old 09-21-2011, 10:57 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
yes you can get it at any siding supply house
Tom Struble is offline   Reply With Quote
Old 09-22-2011, 07:43 AM   #3
Actually, finding aluminum siding could be difficult. Check building supply houses, usually only available in 8" white, and if you find it , it will not match what you have. You old stuff is aged and faded.
Old 09-22-2011, 08:01 AM   #4
SFX Group's Avatar
UPDATE
My bad, this isnt metal (at least not the part i have taken a picture of), its some sort of plastic / hard
Vinyl (which has been painted, as there are spray marks on a post nearby the some color as the house).
Pics here.
Many Thanks
Ashley
Old 09-22-2011, 11:28 AM   #5
Rewards Points: 150
From the pics, it looks like an old siding that was made by Gold Bond. The corners also look like the Gold Bond stuff. It was a semi cementious product similar to the current HardiPlank but in a 1x 8. It didn't do well around here because the technology to install it wasn't there yet. It was very hard to work with and equally hard on tools. Driving a nail in it by hand was an experience. If it is the Gold Bond siding, I haven't seen any of it since the mid 80's. Best of luck finding any although you probably could use the Hardi and have it look fairly close.
TrapperL is offline   Reply With Quote
The Following User Says Thank You to TrapperL For This Useful Post:
Tom Struble (09-22-2011)
Old 09-22-2011, 08:14 PM   #6
i think aluminum would match better than hardi,depends on the exposure
aluminum siding is still very much available,you may need to order [8'' probably not] and choices are limited
Can you flash replacement windows with existing siding? twobyfour2 Windows and Doors 3 05-31-2011 10:29 PM
Masonite Siding Replacement kennykenny Remodeling 2 07-20-2010 05:52 PM
Siding replacement question MeatballCB General DIY Discussions 16 02-05-2010 03:53 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
