-   -   Old siding replacement (http://www.diychatroom.com/f19/old-siding-replacement-117961/)
SFX Group 09-21-2011 09:42 PM
Hi
House has siding that’s some sort of hard Vinyl / plastic (i did say metal orginally), its very plain in design, about 8 inches high, just a flat surface that overlap. Has separate corners (will get picture).
We think fitted early to mid 1980's, any idea if there is a replacement as certain parts need to be replaced and a chimney is being removed so needs new parts put in.
Dont really want to replace the whole siding yet...
Tom Struble 09-21-2011 09:57 PM
yes you can get it at any siding supply house
Just Bill 09-22-2011 06:43 AM
Actually, finding aluminum siding could be difficult. Check building supply houses, usually only available in 8" white, and if you find it , it will not match what you have. You old stuff is aged and faded.
SFX Group 09-22-2011 07:01 AM
UPDATE
My bad, this isnt metal (at least not the part i have taken a picture of), its some sort of plastic / hard
Vinyl (which has been painted, as there are spray marks on a post nearby the some color as the house).
Pics here.
http://www.ashleygriffin.ca/temp/elm...e/siding-1.jpg
http://www.ashleygriffin.ca/temp/elm...e/siding-2.jpg
TrapperL 09-22-2011 10:28 AM
From the pics, it looks like an old siding that was made by Gold Bond. The corners also look like the Gold Bond stuff. It was a semi cementious product similar to the current HardiPlank but in a 1x 8. It didn't do well around here because the technology to install it wasn't there yet. It was very hard to work with and equally hard on tools. Driving a nail in it by hand was an experience. If it is the Gold Bond siding, I haven't seen any of it since the mid 80's. Best of luck finding any although you probably could use the Hardi and have it look fairly close.
Tom Struble 09-22-2011 07:14 PM
i think aluminum would match better than hardi,depends on the exposure
aluminum siding is still very much available,you may need to order [8'' probably not] and choices are limited
