Old 07-27-2008, 02:07 PM   #1
Old Register Vents
My husband and I are redoing our bathroom. We live in an old house and the measurements on almost everything are off. I can not find a vent like the one we have. Does anyone know where to find another like this, or how to redo this vent? It is made of metal. This vent in the picture is in one of the bedroom, I just took a picture of that one to show, they are all the same.
linz2005 is offline   Reply With Quote
Old 07-27-2008, 02:57 PM   #2
Building codes guy, Mod
thekctermite's Avatar
Old Register Vents
You probably won't find one like that.
You can have it sand-blasted or bead-blasted, and it probably won't cost much. Most paint shops can do this for you, or look up media blasters or sand blasters in the phonebook. That will strip all the paint and leave you clean raw metal.
I bead-blasted my HVAC vents, and was shocked that they rusted wherever my fingers touched them...Overnight! So, use caution handling them when they've just been blasted. Hang them from the ceiling and spray the entire surface with rust-inhibiting spray primer. Once the primer is dry, use spray paint to get the color you want.
The hard way to do it would be with sandpaper, but it could be done. It will take a loooooong time though.
thekctermite is offline   Reply With Quote
Old 07-28-2008, 07:30 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
Old Register Vents
Try an antique store or house wrecking shop?
Old 07-28-2008, 09:25 AM   #4
Whatamess
Old Register Vents
Find a place that does powder coating and check those options. Will last almost forever.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 07-28-2008, 10:37 AM   #5
Old Register Vents
Ooh...Good idea! Powder coating will stand up to almost anything, and most powder coaters can media blast the old paint off the metal!
More On This Topic
Hi, I'm Doug I work with 20 great guys in Saint Louis at Doug Jenkins Custom Hot Rods and we are going to do some work for you today on Expert Village. The next step that Alex has going here is a little spot blaster with a vacuum cleaner attached. In the... Read More »
Hi. I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods and we are going to do some work for you today on Expert Village. In order to get all the little nooks and crannies inside here perfectly rust free, Alex is using a... Read More »
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. Okay now we're going to get ready and mix some etch primer. Tony's putting on the clean suit. And... Read More »
Hi, I'm Doug. I work with 20 great guys in St. Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Now Andy's applying the second coat of black on this. The first layer of material we put on was a primer... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be removing rust. Now if you have a mower where there is lots of rust starting to accumulate on it and you want to try and preserve the life of your mower just a little bit longer... Read More »
Small register vents Need source bofusmosby Carpentry 9 07-15-2008 08:26 AM
ridge/soffit vents not enough?? cbice74 Roofing 1 06-16-2008 06:02 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 06:26 AM
sofit vents + gable end vents no ridge vent mattg1970 Roofing 5 10-18-2007 10:47 AM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 05:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
