Old Paper-backed Insulation = Vapour Barrier? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 08:42 AM   #1
Old paper-backed insulation = Vapour Barrier?
From what I've heard, on old paper-backed insulation (R8?) the paper acts as a vapour barrier. Here's my dilemma:
I am redoing an old house but I don't want to tear apart the attic because the current insulation (paper-back+blown) is below floor boards in about 1/2 the space.
In the other parts, I had to pull up boards to drop wires and vents. I would like to use a thick vapour barrier rated paint on the ceilings to ensure this barrier is continuous.
Will the paper-backed insulation cause a problem due to a "double-vapour barrrier" or is this not an efficient vapour barrier in the first place?
On another note, when I blow more insulation into the attic when I am done, I know to install the channel vents, but do you also put a small barrier to prevent the blown insulation from falling onto the soffit around the channel vent?
Thank you.
billyh is offline   Reply With Quote
Old 03-15-2011, 11:01 AM   #2
Rewards Points: 1,092
If the paper is laminated w/ asphalt, it has a perm of 0.3 (Class I vapor retarder), but it is leaky. VR paint has a perm of about 0.45. I don't think you'll have a double vapor barrier problem because of the proximity of each, but I could be wrong. Both should be at the same temp, w/ only sheet rock between them, so they should not condense. Yes, block the blown from escaping.
The Following User Says Thank You to jklingel For This Useful Post:
billyh (03-15-2011)
Old 03-15-2011, 01:39 PM   #3
I think that is what it is. It is paper like a brown paper bag, with the bottom of the lower paper black (doesn't really increase the thickness at all).
Thanks for the help.
Old 03-15-2011, 08:38 PM   #4
Registered User
Rewards Points: 5,516
Read the % solids content on the v.b. paints, not all are the same; http://www.mde.com/publications/Jan07News.pdf
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 09:11 AM
vapour barrier HELP!!!!! 06GT General DIY Discussions 8 02-23-2010 08:01 AM
Installing New Electrical Outlet - Vapour Barrier WhIsKeY Electrical 4 12-31-2009 11:08 AM
moisture behind vapour barrier piperboy General DIY Discussions 9 10-21-2008 12:49 PM
