Old Footing And Slab On Grade - Is It A Crack R Expansioin Joint - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 06:11 PM   #1
Old Footing and slab on grade - is it a crack or expansioin joint
The slab is approximately 50 years old, and I'm replacing a few rotten wall studs along the perimeter of one edge of the slab.
I found what, at first glance appeared to be a crack just inside the 2x4 PT sill. The crack was 7' long, 1/8 inches wide, and 4 inches deep. Upon further probing it looked too even to be a crack, and it ended as a perfect corner - where the foundation jogged.
Is it possible that where stem wall of the footing rises up to meet the sill it is only 4 inches wide, and the slab was poured separately allowing for an expansion gap? Has anyone ever seen a footing that might be similar to this one? See diagram...
Old Footing and slab on grade - is it a crack r expansioin joint-footing-diagram.jpg   Old Footing and slab on grade - is it a crack r expansioin joint-p5240078.jpg   Old Footing and slab on grade - is it a crack r expansioin joint-p5240082.jpg   Old Footing and slab on grade - is it a crack r expansioin joint-p5240084.jpg
lakemans is offline   Reply With Quote
Old 05-24-2012, 06:36 PM   #2
Rewards Points: 13,458
Post a picture.
Old 05-24-2012, 07:06 PM   #3
Rewards Points: 3,528
Seen a lot of garage's poured that way,but the floor was not level with the stem wall,floors were always 6 inches below the wall.
Canarywood1 is offline   Reply With Quote
Old 05-24-2012, 07:19 PM   #4
So you think it's not a stress crack, rather that the slab and the footing were not poured at the same time, and the stem wall was intended to be only 4" wide? Seems a bit thin to support the load of the walls and roof.... Still, it does appear to be designed that way....
Old 05-24-2012, 07:38 PM   #5
Yes i've seen a lot of them,the bottom plate just fits on the stem wall.
The Following User Says Thank You to Canarywood1 For This Useful Post:
lakemans (05-24-2012)
How to pour a replacement piece of footing? Homerepairguy Concrete, Stone & Masonry 2 02-29-2012 12:51 PM
Ran into footing while moving plumbing under slab. tony w Building & Construction 5 01-19-2012 01:44 PM
enclosing garage, non-load bearing stucco wall - do I need to cut slab & dig footing? eric559 Building & Construction 3 07-07-2010 01:41 AM
Adding a footing to an existing slab on grade jascox Building & Construction 4 07-05-2010 02:20 PM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
