-   -   Old Footing and slab on grade - is it a crack r expansioin joint (http://www.diychatroom.com/f19/old-footing-slab-grade-crack-r-expansioin-joint-144757/)
lakemans 05-24-2012 07:11 PM
Old Footing and slab on grade - is it a crack or expansioin joint
4 Attachment(s)
The slab is approximately 50 years old, and I'm replacing a few rotten wall studs along the perimeter of one edge of the slab.
I found what, at first glance appeared to be a crack just inside the 2x4 PT sill. The crack was 7' long, 1/8 inches wide, and 4 inches deep. Upon further probing it looked too even to be a crack, and it ended as a perfect corner - where the foundation jogged.
Is it possible that where stem wall of the footing rises up to meet the sill it is only 4 inches wide, and the slab was poured separately allowing for an expansion gap? Has anyone ever seen a footing that might be similar to this one? See diagram...
joecaption 05-24-2012 07:36 PM
Post a picture.
Canarywood1 05-24-2012 08:06 PM
Seen a lot of garage's poured that way,but the floor was not level with the stem wall,floors were always 6 inches below the wall.
lakemans 05-24-2012 08:19 PM
So you think it's not a stress crack, rather that the slab and the footing were not poured at the same time, and the stem wall was intended to be only 4" wide? Seems a bit thin to support the load of the walls and roof.... Still, it does appear to be designed that way....
Canarywood1 05-24-2012 08:38 PM
Yes i've seen a lot of them,the bottom plate just fits on the stem wall.
