Old Drywall/plaster Lathe...what Is It? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2009, 10:54 AM   #1
Rewards Points: 156
old drywall/plaster lathe...what is it?
I have a 1940s house and the walls are all plaster. Underneath the plaster finish, there is a rock mixture and then there is some kind of board which looks a lot like modern drywall. It's about 1/4" thick and in approx 2' x 4' sheets. Other houses in the neighborhood have the old time wood lathe under the plaster. What kind of board do I have? Anyone know?
jayp is offline   Reply With Quote
Old 04-01-2009, 12:53 PM   #2
joed's Avatar
Rewards Points: 11,614
It was the transition between wood lath and drywall. It was called rock lath and most that I have seen was 16"x4' sheets. It replaced the wood part of the wood lath and plaster walls. It went up much faster than nailing all the small wood strips.
Old 04-01-2009, 12:53 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
What you have is "rock lath". That was the name for sheet material that was applied to walls and was then plastered over. A lot of 1940s-50s-60s buildings used it before drywall became popular. Rock lath was originally a brand name for plaster board. It is normally 16"x48"x3/8", but there were other variations. Rock lath eliminated the base scratch coat that got applied to wood lath.
Old 04-01-2009, 01:27 PM   #4
Registered User
Rewards Points: 4,936
Interesting reading: http://www.nps.gov/history/hps/tps/briefs/brief21.htm Be safe, GBR
Old 04-01-2009, 06:51 PM   #5
joed's Avatar
And to correct common mistake it is lath not lathe. Lathe is a tool for make things round.
A wood lathe.
Wood lath
Old 04-01-2009, 08:01 PM   #6
Rewards Points: 156
thanks
Thanks guys -- you're exactly right. It was 16"x4'. I'll tell ya --- that plaster & rock lath is saving me a little money on heating and AC since there is no insulation behind it! Just a little money though -- better than plain drywall.
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
Just bough an old lathe - need some help wombosi Tools 17 03-12-2009 10:08 PM
Plaster and Lathe walls- covering with drywall Jrr1099 Building & Construction 4 03-24-2008 03:20 PM
Plaster walls and Lathe Keith in Connecticut Remodeling 5 01-03-2008 08:36 PM
replacing lathe and plaster eager2lern Building & Construction 2 12-04-2006 01:52 PM
