Old Deck Nails - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 10:52 AM   #1
Old deck nails
Nails are coming up on my 25 year old deck. Can they be replaced with screws? Do I need to fill the holes with something before using a replacement screw?
owrens is offline   Reply With Quote
Old 09-03-2011, 11:23 AM   #2
Rewards Points: 6,652
If the nails are coming up and the deck is 25 years old, I would say that it is time to replace the deck.
Old 09-03-2011, 11:32 AM   #3
Rewards Points: 150
Yes if you can get the nails out cleanly and you can get screws with outer diameter wider than the nails were. My dad did this on his deck because the builder he hired failed to use galvanized nails and they started to rust immediately. Unfortunately the builder also nailed the nails in at an angle so it caused the screws to not lay flat. Still better than it was.
BTW, my deck is 29 years old and some of the nails are gradually working up, but the lumber is still good. I'll first try to hammer them back down, but if they don't stay, I'll try to replace with screws.
NancyNGA is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Refinishing / Repairing Deck: Screws vs. Nails? superhandymom Building & Construction 1 05-10-2010 02:08 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Deck nails jimgibson Carpentry 12 10-09-2005 02:22 PM
