Old City Storm Sewer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 07:42 AM   #1
Greetings,
I moved into my first "old" house last year and had a question about the storm sewer lines. The downspouts were already disconnected from the round cast iron pipes around the perimeter of the house which I'm assuming were part of the old storm sewer system that is no longer (or shouldn't be) used.
The pipes are open, with no caps. Should they be capped off? If so, what would you use to cap them off? My local hardware store wasn't much of a help part-wise.
Thanks!
Jimmy B
jimmycrackcode is offline   Reply With Quote
Old 03-14-2012, 08:00 AM   #2
Metal Coffee can cut out lids work good and then mix red mix cement and fill in on top of metal, Last for ever. This will work if you have bells on the cast iron pipe.
Hardway is offline   Reply With Quote
Storm Sewer Backwater Valve Failure House isa Mess Plumbing 0 12-04-2011 12:02 PM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
connect sewer to city sewer yuzhenli Plumbing 1 01-31-2010 07:10 PM
Broken, busted, clogged storm sewer line... Upstate Steve Plumbing 1 04-07-2009 11:26 AM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
