Okay To Use Flashing Under Fiberglass/concrete Deck Coating? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 11:54 PM   #1
Rewards Points: 682
Okay to use flashing under fiberglass/concrete deck coating?
I am going to have a fiberglass/concrete deck coating installed, I am replacing the sheathing on the walls around where this coating will be installed. Can I place aluminum flashing where the sole plate of the wall and plywood floor meet? The flashing would extend under the fiberglass and concrete coating.
I think they are using a material called elasticrete latex.
darsunt is offline   Reply With Quote
Old 02-24-2012, 11:59 PM   #2
Rewards Points: 13,712
A picture would sure help.
Are you talking about a fiberglass reinforced concrete deck?
Old 02-25-2012, 11:16 AM   #3
Rewards Points: 682
No, it is that coating that is applied to balcony floors everywhere to keep them waterproof. It is laid over the plywood floor, and then built up a couple of inches up the adjacent walls.
I do remember when they repaired our balconies that there was a great deal of flashing that ran from the walls to underneath the concrete/fiberglass membrane. It looked like it was in good shape. But it was galvanized flashing I believe, not aluminum.
Old 02-25-2012, 12:05 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
Last edited by Tom Struble; 02-25-2012 at 12:07 PM. Reason: never mind,miss read the question
Tom Struble is offline   Reply With Quote
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Deck Support Beam temporary fix. george747 Building & Construction 5 10-17-2011 09:41 PM
tiling deck of a 5 ft corner tub level with tub deck Blue Falcon Carpentry 16 09-28-2011 12:55 PM
Deck Coating moff Painting 0 08-07-2010 02:23 PM
