Okay To Lay Floor Membrane On Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 02:26 AM   #1
Rewards Points: 682
Okay to lay floor membrane on siding?
I've seen that fiberglass/concrete balcony flooring laid on fresh plywood, and on older membrane. Is it okay to put it on flashing as well?
darsunt is offline   Reply With Quote
Old 02-21-2012, 06:27 AM   #2
DIY staff
Rewards Points: 7,174
A few more details---where are you going to do this?
Under siding would be bad in most cases--the structure need to breathe tar paper or Tyvek do that.
Old 02-21-2012, 07:20 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
There's something called "balcony flooring"?
titanoman is offline   Reply With Quote
Old 02-21-2012, 12:14 PM   #4
Rewards Points: 682
Waterproof in front of exterior door over plywood. Sides around the door just nail in wood, or run flashing behind and under the wood? I think I've seen flashing at the sides of a waterproofed balcony.
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 07:56 AM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
