-   -   Okay to lay floor membrane on siding? (http://www.diychatroom.com/f19/okay-lay-floor-membrane-siding-134448/)
darsunt 02-21-2012 01:26 AM
I've seen that fiberglass/concrete balcony flooring laid on fresh plywood, and on older membrane. Is it okay to put it on flashing as well?
oh'mike 02-21-2012 05:27 AM
A few more details---where are you going to do this?
Under siding would be bad in most cases--the structure need to breathe tar paper or Tyvek do that.
titanoman 02-21-2012 06:20 AM
There's something called "balcony flooring"?
darsunt 02-21-2012 11:14 AM
Waterproof in front of exterior door over plywood. Sides around the door just nail in wood, or run flashing behind and under the wood? I think I've seen flashing at the sides of a waterproofed balcony.
