I am building a shed in the back yard......
Behind my garage I have a perfect spot . I can put a 12x12 shed and only have to build 2 walls to do it.
Basically I am going to attach the 2 walls to the back of the garage and to the side of the house, then I can continue the roof line right down....... My delema is how do I attach to the stucco, and be water tight?
I have had Ideas of taking a circular saw, and cutting out the stucco where the roof will attach to the house. This way I can get the flashing under the stucco as if it were built that way, then no leaks in the shed.
But do you guys have any better ideas?
PS don't worry about the Central unit I am having that moved to the other side of the house. Also do you think I need to pour footings for this application? Most times a shed on pad is ok but this will be attached to the home. Thanks.
If the pic don't work here is the link
http://community.webshots.com/photo/...56333749orttFI
