Is It Ok To Run On A Treadmill On The 2nd Floor Of My Split Level Home? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 11:18 AM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Is it ok to run on a treadmill on the 2nd floor of my split level home?
I want to put a treadmill in my exercise room. Its a split level and the exercise room is over the garage. Is it ok for this, weight wise and from a structural point.
J187 is offline   Reply With Quote
Old 01-28-2009, 11:57 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,...
How Large are the folks using the room,..??
What's the floor do Now if they're doing, say Jumping Jacks,..??
Old 01-28-2009, 03:52 PM   #3
J187's Avatar
Rewards Points: 516
We aren't very large at all. A 175lb man and a 125lb woman. IF we did jumping jacks absolutely nothing would happen.
Old 01-28-2009, 04:07 PM   #4
Bondo's Avatar
Ayuh,...
I doubt the weight of the machine itself could possibly be high enough to Break the Idea....
It would probably spread the load of the weight of the impacts from running,...
I'd say, Go for it...
Old 02-09-2009, 08:54 AM   #5
J187's Avatar
Rewards Points: 516
Thank you so much for the response. I would be interested in hearing others weigh in as well. Any other opinions?
Old 02-09-2009, 09:22 AM   #6
Remodeling Contractor
If your doctor says okay then the pros here say so also.
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Home Improvement/Remodeling Contractor Website Possibility? newigal General DIY Discussions 6 01-03-2006 09:38 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
