Is It OK If Studs Do Not Meet In The Very Corner ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2008, 12:27 PM   #1
Rewards Points: 1,062
Question
is it OK if studs do not meet in the very corner ?
i am doing some hard-to-reach framing and have some corners where studs will not meet in the very corner. i was wondering if that is okay ? please see the illustration.
Old 07-14-2008, 01:06 PM   #2
Rewards Points: 1,220
No it isn't.
Tscarborough is offline   Reply With Quote
Old 07-14-2008, 01:09 PM   #3
Jay123's Avatar
It will be fine...but only if you like the ends of your drywall to be "moveable". You need the corner studs to support your drywall ends.
J
Jay123 is offline   Reply With Quote
Old 07-14-2008, 01:18 PM   #4
Framing Contractor
If you know #1 is right, why would you think #2 is okay when it has no nailers for sheetrock??? Are you trying to save on studs?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-14-2008, 01:36 PM   #5
what if it is only 2-3 inches away. drywall is not bendable within that range. it would have to be a couple of feet at least.
why do it this way ? ad hoc construction, i guess. everything else turned okay. i guess i can still fit studs to meet at corners but it would not be possible to reach with my best buddy Makita. may have to manually nail it.
Old 07-14-2008, 01:53 PM   #6
Framing Contractor
What's, "ad hoc construction"?
Who's your buddy Makita? Is he a screw gun? What's wrong with nailing by hand?
Joe Carola
Old 07-14-2008, 01:59 PM   #7
ad hoc means i did not draw a plan, instead relied on on-the-fly assessment. worked well for the most part. who wants to plan to position of every stud. it is a delicate spot that required efficient use of space (bathroom) and dipsy-doodling around some pipes etc. extreme framing ...
Makita = framing nailer. why not manually - ahh ... laziness. i guess i will do it.
Old 07-14-2008, 04:23 PM   #8
Rewards Points: 5,336
If you don't want to do it correctly, why do it at all.
Ad hoc be damned, whoever he is!
Ron
Old 07-14-2008, 04:29 PM   #9
Registered User
Termite's Avatar
You need studs at each side of the corner. No ifs, ands, or buts.
Old 07-14-2008, 05:24 PM   #10
BUILDER / REMODELING CONT
buletbob's Avatar
correct. You will be spackling that corner every year. DOES IT PAY.
Old 07-14-2008, 05:28 PM   #11
Custom Cabinet Maker
NO, NOT,NYET,NINE,NON
Just build your corners before you stand the studs, just like a normal corner, or partition block. Make a "L" corner so you have 3 1/2 on flat going into corner.
skymaster is offline   Reply With Quote
Old 07-14-2008, 05:40 PM   #12
so the rule of thumb that i just learned is BUILD CORNER STUDS BEFORE WHAT GOES IN B/WEEN. is that a sound lesson ?
Old 07-14-2008, 06:24 PM   #13
Yes,right,sure,absafrakenlutely, always and ever imho
Old 07-14-2008, 06:29 PM   #14
thank you all !
Old 07-14-2008, 09:20 PM   #15
Amakarevic: Please understand nobody is hollering at ya
Now Lets fix this puppy,How far away from the corner is each space?
Let me try that in English, from each stud how far do we have to close in?
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 11:16 PM
Removing 2 walls - corner post issue (pics) LadyNimue Building & Construction 7 01-06-2008 01:35 PM
How to mud three wall/ceiling meet corner? KUIPORNG Remodeling 6 03-24-2007 01:51 AM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
