Ok To Hang I Joist To Dimensional Lumber Header? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-03-2016, 10:41 PM   #1
Rewards Points: 310
Ok to hang I joist to Dimensional lumber Header?
Span is 30" crawlspace. Header is 4x12 dimensional lumber. I used appropriate I joist hangers for sized I joist. Thoughts? Figure I'll use the DIY Chatroom inspectors before the real one lol. The rim joist will also span opening
https://www.amazon.com/clouddrive/sh...hare_link_copy
PandJ is offline   Reply With Quote
Old 04-03-2016, 10:52 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 562
Re: Ok to hang I joist to Dimensional lumber Header?
I'd add stiffeners between the web and the hanger.
The Following User Says Thank You to TheEplumber For This Useful Post:
PandJ (04-03-2016)
Old 04-03-2016, 10:54 PM   #3
Rewards Points: 310
Ah yes! Good call will add tomorrow. Thank you for catching that.
Old 04-04-2016, 08:18 AM   #4
Rewards Points: 13,456
If your in the building stage not just trying to do a repair I'd be using one like this.
http://www.strongtie.com/topflangeha...c/p/hutf.hustf
Old 04-04-2016, 09:48 AM   #5
Rewards Points: 310
These are for sawn dimensional lumber. I'm using I joist. I'll double check to see if there is something heavier duty available.
I'm guessing ok to use the beam to hang. I own a few different high rated framing books and this stuff is not noted. Thanks for feed back
Termite damage and your opinion on mended joist integrity 5tudent Roofing/Siding 2 12-04-2015 03:07 PM
Is plywood or dimensional lumber better for repairing notched joist? darkins General DIY Discussions 3 06-04-2014 11:55 AM
Need to determine proper Basement Window Header size- AdamH Building & Construction 1 11-23-2011 02:59 PM
Garage Header rwbil Building & Construction 11 09-16-2010 11:50 AM
Hang wall from floor joist HooKooDooKu Building & Construction 3 01-04-2010 08:50 AM
