Is It Ok To Caulk Where Siding Overlaps Brick? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 09:22 PM   #1
Is it ok to caulk where siding overlaps brick?
My house is a 2-story, brick on bottom & vinyl siding on top. Every year without fail, I find a couple of places where honey bees find gaps where the siding overlaps the brick, and try to make a nest inside. I hate having to kill the bees; I'd rather prevent them from entering in the first place. Is it ok to fill all of the gaps with caulk, or is this a no-no because of drainage/moisture build up? If it's ok, what type of caulk should I use?
Thanks!
Xig
Xiggy is offline   Reply With Quote
Old 09-07-2009, 11:32 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
you can caulk holes inbetween the siding and brick
use a polyurethane siding caulk you can get it to match most colors
most well stocked lumberyards or better a roofing/siding distributor can help you
Tom Struble is offline   Reply With Quote
Old 09-08-2009, 06:10 AM   #3
There are usually small drain holes in the bottom of vinyl siding, don't cover those.
Old 09-08-2009, 08:52 PM   #4
Thanks for the tip on the caulk. I'm not sure if what I'm looking at are drain holes though. What would those look like? I've attached a picture of the gaps, with a "circle" around where the bees like to sneak inside. Are these drain holes? Would it be ok to fill these with caulk then run a bead along the brick/siding between the gaps?
Thanks again!
Xig
Old 09-09-2009, 05:35 PM   #5
yes you can caulk those holes
the small holes in the bottom of the panel are what the
other poster was talking about
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 02:01 PM
Replacing Brick with Wood siding HLB Carpentry 1 06-11-2009 10:17 AM
Siding and Brick veeneer wall? sandyman720 Building & Construction 9 08-13-2007 04:02 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
