Oil Stain On Concrete Driveway. What Is The Best Way To Deal With This?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 07:21 PM   #1
Oil stain on concrete driveway. What is the best way to deal with this??
How do I remove oil stains on concrete driveway? Is it impossible (I think so). Should I get something to cover it up? I tried the water pressure machine, I tried a cleaner, and did not work. Please help!!
mjeffersondc is offline   Reply With Quote
Old 01-08-2012, 07:32 PM   #2
MarginallyQualified
Rewards Points: 2,464
You'll need an enzyme product to get the oil up.
The stain? Time (or maybe a bleach).
hth
Old 01-08-2012, 07:33 PM   #3
Rewards Points: 13,450
Dry using Simple Geen or an Orange cleaner, scrub it with a stiff brush, let it soak in an hour hose it off, and do it again.
May not get it all but it sould be better. And find and fix that leak or park over one of those big drip pans.
Old 01-08-2012, 07:34 PM   #4
DIY staff
Rewards Points: 7,174
Powdered Tide detergent works ---get the concrete wet---make a paste out of the powder--broom it in
cover with plastic to keep it wet--let it work--hose it off----that's about as good as you will get--
Old 01-08-2012, 07:43 PM   #5
Thank you everyone!! When this happened before, we covered it up with "crete clean miracle mud concrete cleaner", but I can't find it in the stores anymore
Old 01-08-2012, 11:47 PM   #6
How old is the stain? if it's new, start by covering it with an absorbent product (kitty litter is the cheapest), grind the absorbent in, and sweep it up. Hit any remaining spots with brake cleaner (the kind you buy in a can at NAPA,) and wipe it up.
If it's an older stain, you may have to resort to the acids. I would start with Coca Cola, letting it sit over night. If that does not work, you can up the anti with some Muriatic acid, but don't leave it on overnight! And if you end up using the stuff, make sure to read the MSDS first!
Good luck!
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 01-09-2012, 03:25 PM   #7
Rewards Points: 410
I've had the best luck with motar mix , applied dry and left on for a day or two.
High Gear is offline   Reply With Quote
Old 01-09-2012, 03:35 PM   #8
Thank you everyone. I just put the tide paste on. Now it is covered with plastic. Do I leave it overnight? If that doesn't work, I will try Coca Cola (I can't believe we are allowed to drink this) on the driveway. If that doesn't work, I will try bleach, that muriatic acid.
These are old oil stains, that my car keeps adding stains too. Wish me luck.
Old 01-09-2012, 03:36 PM   #9
I will try motar mix and/or the orange lener if that doesn't work
Stain a large concrete patio (or paint?) ArizonaJay Painting 1 11-14-2010 01:02 PM
Concrete driveway cost per sq. foot? Flt_Simulation Building & Construction 1 06-20-2009 06:25 AM
Concrete stain on painted sloped floor ur_real_dad_21 Flooring 4 01-09-2009 11:38 AM
Concrete Pavers and Stain terryhflyer Flooring 2 06-04-2008 04:59 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 04:19 PM
