Old 08-18-2006, 12:43 AM   #1
MLO
Odd size foundation vents...
Our remodel will have 9" foundation walls. I can only buy vents for a 6", 8", or 10" wall. I do not want to put the vents into the rim-joist as the wall will be bricked. This is a 400 sq. ft. addition on a 50 yr. old home that is being made to match existing. Any suggestions?
MLO is offline   Reply With Quote
Old 08-19-2006, 12:32 PM   #2
MLO
My thoughts were to just buy the 10" wide vents and cut the flange down to 9". Anyone see a problem with this?
Old 08-19-2006, 06:46 PM   #3
Is the 9" the foundation wall thickness or the opening size?
redline is offline   Reply With Quote
Old 08-19-2006, 07:00 PM   #4
MLO
Wall thickness... I was just told that they used to make adjustable vents for use in 6-8" walls. I guess it was sort of a sleeve type set-up for adjustability. Anyone ever see em or know if they available in larger widths?
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
blow power of vents mcvane HVAC 5 08-11-2007 04:28 PM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 09:26 PM
Reducing size of very large air-vent returns in floor? AllGoNoShow HVAC 3 09-19-2006 10:36 PM
