-   -   Odd size foundation vents... (http://www.diychatroom.com/f19/odd-size-foundation-vents-3533/)
MLO 08-17-2006 11:43 PM
Our remodel will have 9" foundation walls. I can only buy vents for a 6", 8", or 10" wall. I do not want to put the vents into the rim-joist as the wall will be bricked. This is a 400 sq. ft. addition on a 50 yr. old home that is being made to match existing. Any suggestions?
MLO 08-19-2006 11:32 AM
My thoughts were to just buy the 10" wide vents and cut the flange down to 9". Anyone see a problem with this?
redline 08-19-2006 05:46 PM
Is the 9" the foundation wall thickness or the opening size?
MLO 08-19-2006 06:00 PM
Wall thickness... I was just told that they used to make adjustable vents for use in 6-8" walls. I guess it was sort of a sleeve type set-up for adjustability. Anyone ever see em or know if they available in larger widths?
