Odd Framing Isssue - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2013, 08:41 PM   #1
Rewards Points: 216
odd framing isssue
i am looking for suggestions here. see pic.
2 rafters are coming down to where there was a wall, years ago. what was supporting those rafters, that i took down, was laughable. now i need to support them. there isn't a ton of weight there. but i think it could bow 2x6's enough to notice. so i am thinking a 2x10 or 2x12 JUST to hold them up.
but, perhaps there is something i am not seeing. if so, let me have it.
Fix'n it is offline   Reply With Quote
Old 07-29-2013, 12:28 AM   #2
Registered User
Rewards Points: 5,216
The ceiling joist is tapered more than 1/2 its depth so it is almost useless. I'd double the c.j. to the right of window, hanger/double a new built-up beam against the tapered one to carry the roof valley and room c.j.'s. New bearing to earth in existing lath wall. Leg-up cripples to support roof valley from triple (sandwiched side/ exist. tapered).
Use positive connectors on/as rafter/c.j. nailing is missing against wall spreading; see table listed; http://publicecodes.cyberregs.com/ic...9_8_par022.htm
Gary
Old 07-29-2013, 09:04 PM   #3
Rewards Points: 216
thanx, Gary
that joist you see, there are 3 of them. nailed and bolted together. so that joist is 4 1/2" thick. the other side joist, the taper goes all the way to the roof sheathing.
as to my issue. i am going to put a 2x8. just raise it up a little, so that if it does sag a little, it will not be part of the ceiling joists.
Framing question, basement/first floor remodel enoll Remodeling 0 02-22-2012 01:01 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
