Old 03-28-2010, 01:02 PM   #1
NE78FJ40's Avatar
Oak fireplace surround
I am installing a fireplace in my soon to be finished basement. The mantel and surround I am using is premade of oak. The floor is my basement is concrete. I know you are not supposed to have untreated wood in contact with concrete. Do I need to put something between the concrete and the wood? What should I use?
Below is an example of the fireplace enclosure I'm using, only mine is unfinished oak. I will be staining it at a later time.
NE78FJ40 is offline   Reply With Quote
Old 03-28-2010, 01:16 PM   #2
Tool Geek
PaliBob's Avatar
Thumbs down
Originally Posted by NE78FJ40 View Post
.................I will be staining it at a later time.
Bad idea. What if you have a sudden water leak? Water will wick up the end grain and stain the wood permanently.
I would first stain and finish the mantle on all sides with multiple coats then for extra insurance apply a layer of epoxy on the bottom side end grain. Then after all sides were sealed do the installation.
& Stay Safe
.....Bob Lavery
Need some help with Fireplace base and surround bowanna03 Carpentry 4 03-14-2010 05:37 PM
Added new Fireplace Surround need drywall tips rocketdoctor Drywall & Plaster 2 12-06-2009 07:14 AM
prepping a fireplace surround for tile rocketdoctor Building & Construction 3 11-30-2009 11:53 PM
Removing Granite & Omni Grip Adhesive from Fireplace Surround RayJak Tiling, ceramics, marble 4 11-13-2009 04:28 PM
Fireplace Surround Remodel baksdak Project Showcase 5 03-06-2008 01:28 PM
