Old 09-03-2012, 09:44 AM   #1
notching rafters depth help please
Im using 2x12 rafters.12 12 pitch cathederal ceilings. My plans tell me i can only birdsmouth cut 1/6 of my rafter. Does this sound right? I guess for strength of board? Only gives me a 2" notch.
driftwoodtackle is offline   Reply With Quote
Old 09-03-2012, 11:17 AM   #2
Being at the end of the rafter, the bending stress is almost zero so you can notch it deeper than that, particularly for a 12" rafter.
The important point is to get a good full bearing on the wall plate.
tony.g is offline   Reply With Quote
Old 09-03-2012, 11:21 AM   #3
See if this helps
notching rafters depth help please-notch-bore-studs.jpg   notching rafters depth help please-frame-guidelines.jpg
hammerlane is offline   Reply With Quote
Old 09-03-2012, 11:28 AM   #4
12 pitch i would go full bearing 3 1/2" or 5 1/2" seat cut depending on exterior wall size
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 09-03-2012, 11:41 AM   #5
Our plans only allow 1/6 nominal depth. If i use 2x12 that is only 2 inches.
Old 09-03-2012, 11:47 AM   #6
Call your arch, I'm sure he would rather have full bearing than 2 inch...the 1/6 is probably a generic side note.
The deeper the birdsmouth doesn't weaken the rafter until you go past full bearing.
But if there is floor joists next to the rafter then 2 inch is fine. Cut and be done with it.
Old 09-03-2012, 01:15 PM   #7
GBrackins's Avatar
a bird's mouth is not a notch, not in the traditional sense of a notch. It is a bearing seat cut. what you have is a cantilever for the overhang that extends past the wall.
check out comments from the "Building Codes Forum"
http://www.inspectpa.com/forum/showt...t=rafter+notch
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 09-03-2012, 09:15 PM   #8
Moderator
Beat me to it, Gary! LOL Well, here's the other one; http://publicecodes.cyberregs.com/ic...?bu2=undefined
Gary
Clothes taking longer to dry?
Old 09-03-2012, 09:24 PM   #9
GBrackins's Avatar
and the two will make a whole ....
Gary
Notching Roof Rafters to Headers dabelms Building & Construction 12 04-13-2012 07:54 PM
Furring out existing 2x6 rafters kirylm Building & Construction 27 02-13-2012 11:10 PM
checking the rafters joefromcal Carpentry 3 10-01-2010 09:12 AM
Notching Pergola Rafters Azrocks Building & Construction 0 04-26-2010 08:22 PM
