Notching Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 11:26 AM   #1
Electrician
Proby's Avatar
Notching joists
How concerned should one be if the tops of 2x8" ceiling joists have been notched about 3/8" deep to allow wiring to fit in and put flooring on top in an attic? I know it's against code and all and it shouldn't be done, but is this a realistic safety concern? If found, should it be looked into and possibly remedied by a professional?
Proby is offline   Reply With Quote
Old 07-28-2010, 02:35 PM   #2
Totally screwed together
3/8" Notching isn't that deep. While it isn't the ideal way to run wire or pipe, it is allowed providing the joist isn't already overloaded.
xxPaulCPxx is offline   Reply With Quote
Old 07-28-2010, 03:11 PM   #3
Registered User
Rewards Points: 5,216
No notches in the middle 1/3 of span. This is where the compression of the fibers are the greatest under load: http://www.cciccweb.org/files/Framing.pdf
How long a notch?
Be safe, Gary
Old 07-28-2010, 03:16 PM   #4
Electrician
Proby's Avatar
Just enough to get wires thru, maybe 5/8" wide or so.
I thought you were allowed to notch at all, I thought you were only allowed to drill thru the center 1/3 of joists or studs.
Old 07-29-2010, 12:42 AM   #5
Registered User
No notches in middle 1/3 --- that's because when the board bends under load, the top 1" of the joist fibers are under compression and the bottom 1" (or so) are under tension. To notch in this critical area reduces the joist from it's rated strength to a lower rating. If a 2" deep notch---- it would then be equal to the next size lower joist and that rating for loads. Not exactly 2" as joists go: 5-1/2, 7-1/4, 9-1/4, etc. I'm not a S.E. and don't know the exact figures. You could ask our Daniel on here..... or check out the Engineering forums for the answer of that small of a notch. http://books.google.com/books?id=iwS...num=3#PPA32,M1
Be safe, Gary
notching out joists marly Roofing/Siding 1 07-06-2010 11:09 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
Noob Needs Help With Notching In Floor Joists! Bazzy Building & Construction 3 10-19-2009 04:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 01:48 PM
