Notching Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 05:07 AM   #1
Notching Joists
ya you arent supposed to and all. However I am running a beam that is replacing a load bearing a wall that I am about to tear down... and I want to hide the GL beam a bit as it is a 6" x 13" x 16' . So my engineer says I can notch joists around 5 and a half inches for each joist of the 2nd floor and the beam will go through them all and rest on 2x6 ends.... So I assume this is kosher as he said I could do it and its on the plans... however I am wondering how much can I deviate.... basically how much can I notch since the beam basically reinforces each joist... can I do 6, 7, 8, 9inches?? Heck can I just remove the joists entirely where the beam goes and have the joists be connected with simpson hangers to the beam itself? These are 11 -7/8 "I" joists by the way.
Second questions, I should brace the joists with 2x4 on both sides of EACH joist, so there are 6 joists, that means 12 braces? Can I run a 16 foot 2x4 along the entire ceiling on both sides of where the beam is going in.. basically right next to it a few inches.... and then a 2x4 holding up each joist at all 6 joists on both sides = 12 2x4 braces....then I jack the beam up and walla. Yes I have plans, permits, yada yada, I am going to do it myself so tell me if I am going about it right please.
jace781 is offline   Reply With Quote
Old 03-22-2012, 05:30 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 802
1st Question....here is a link that explains what and where to notch...I would not go outside these boundries...
http://ftp.resource.org/codes.gov/bs...awood.S560.pdf
2nd Question...not sure I understand what you mean by braces? Are you refering to blocking?
edit...thanks for adding the 'have permits, etc etc etc'.......otherwise, the next post was going to be "Do you have permits and engineering".......yea, I know, I'm tired of it as well....it's right....but still tired of it...
ddawg16 is online now   Reply With Quote
Old 03-22-2012, 06:58 AM   #3
Civil Engineer
Rewards Points: 4,514
I suggest you run your ideas by the engineer. In my experience, most engineer do not bite, at least not as hard as a bulldog, and anytime you deviate from plans you really need to ask the designer what impact the deviation will have on suitability.
Old 03-22-2012, 07:52 AM   #4
Framing Contractor
Tired of people being asked if they are doing the right thing. That makes a lot of sense. Don't like it...don't comment on it when your not being asked.
Joe Carola
Joe Carola is offline   Reply With Quote
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 06:28 PM
Notching joists Proby Building & Construction 4 07-29-2010 12:42 AM
notching out joists marly Roofing/Siding 1 07-06-2010 11:09 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
Noob Needs Help With Notching In Floor Joists! Bazzy Building & Construction 3 10-19-2009 04:43 PM
