Notched Joists Temporary Solution - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 09:40 PM   #1
notched joists temporary solution
joists notched in middle third of span if I put up a temporary wall and shorten the span will that resolve the issue until I can replace joits?
artmark is offline   Reply With Quote
Old 11-14-2010, 01:26 PM   #2
Registered User
Termite's Avatar
Depends. The notches might not be bad enough to structurally compromise the joists to the point of being detrimental. Adding a wall might add load to something that isn't made to take it (basement slab, joists beneath, etc.).
My advice would be to consider attaching sister joists to the joists to re-structure them. Another viable repair is to use Simpson roll-strapping on the underside of the joists with adequate nailing to restore their tensile strength, if the notches are small. Best advice is to have an engineer take a look at it for you to recommend the best course of action.
Old 11-14-2010, 04:33 PM   #3
Thanks I thought this would spread the load over 3 points? the joists are not sisterable need replacement
Temporary Solution for Severe Basement Mold Problem denny888 General DIY Discussions 1 09-08-2010 01:32 AM
Solution for sagging joists pyper Carpentry 2 08-30-2010 08:10 AM
Tile to tile temporary solution pleasantplainer General DIY Discussions 3 03-15-2010 02:39 PM
Undersized Joists and a solution...I think martinf Building & Construction 15 03-01-2010 12:26 AM
Found 3 notched joists rgsgww Carpentry 9 02-20-2010 12:21 PM
