-   -   notched joists temporary solution (http://www.diychatroom.com/f19/notched-joists-temporary-solution-86638/)
artmark 11-13-2010 08:40 PM
joists notched in middle third of span if I put up a temporary wall and shorten the span will that resolve the issue until I can replace joits?
Termite 11-14-2010 12:26 PM
Depends. The notches might not be bad enough to structurally compromise the joists to the point of being detrimental. Adding a wall might add load to something that isn't made to take it (basement slab, joists beneath, etc.).
My advice would be to consider attaching sister joists to the joists to re-structure them. Another viable repair is to use Simpson roll-strapping on the underside of the joists with adequate nailing to restore their tensile strength, if the notches are small. Best advice is to have an engineer take a look at it for you to recommend the best course of action.
artmark 11-14-2010 03:33 PM
Thanks I thought this would spread the load over 3 points? the joists are not sisterable need replacement
